Stabdžių tvarkymas
storms
Pranešimai: 220
Re: Stabdžių tvarkymas
Standartinė storms » 2016-03-30 15:36
civic rašė:Ką patartumėt dėt GTR 1400 priekiui, diskai kiniški, reikia tik to, kad nevalgytų disko, stabdymui visitek beveik nenaudoju.
Proekiu su tokia karve nestabdai? Stipru...
Bet kokiu atveju tokiam begemotui reikia HH kaladžių.
Jei stabdytum, galėtum nusipirkt rimtas EPFA kalades už paprastų HH kainą
http://www.bikeshop.lt/ebc-vrooam-racing-akcija
Pranešimai: 580
Standartinė informatikas » 2016-03-30 15:38
storms rašė:Street sintered
Special information The SV front axle pad is a perfect combination of high fading-free braking performance, excellent brake feel and thermal stability. This general type-approved pad has been specially developed and is particularly suitable for the requirements of cutting edge sports motorcycles and the stresses placed on high-power machines. The pads are gentle on the brake disc and full braking performance is available immediately and on a stable basis under wet and dry conditions. SV pads are recommended for use in road traffic on the latest generation of sports and touring motorcycles and custom bikes. In racing, you can only use SV pads to a certain extent: TRW offers special linings for this application. The appropriate SH rear axle pad is perfectly adapted to the performance data of the SV on the front axle and matched such that overbraking of the rear brake is avoided. By contrast with the SV pad, you can use the SH mix in all areas of racing on your rear axle.
Tai labai geros :D
storms
Pranešimai: 220
Standartinė storms » 2016-03-30 15:41
Šitos TRW yra geros, bet pakankamai greit dyla. Aišku jei stabdysi ;)
Vejas
Pranešimai: 24
Standartinė Vejas » 2016-03-30 17:44
O kuo EPFA HH geresnes uz FA HH ? Turiu ant vieno motociklo FA HH, labai patenkintas ju veikimu tiek kasdiena tiek track day. Galvoju kurias rinktis.
storms
Pranešimai: 220
Standartinė storms » 2016-03-30 18:19
Jei miksuosi gatvę/žiedą - rinkis EPFA. Jos yra road legal, bet stabdo geriau nei HH. Turi gerą initial bite. GPFAX - not road legal kaladė. Nors aš su jom ir gatvėj važiuoju. Tai yra pačios geriausios iki šiol mano bandytos kaladės, kurios yra lengvai dozuojamos, prognozuojamos ir visiškai nepraranda efektyvumo. Net itin greitose trasose (Brno, Slovakia Ring) nepajutau visiškai jokio fade'o. Visi kolegos, važiuojantys su GPFAX sako tą patį.
Standartinė rusnietis » 2016-06-22 08:20
OEM Nissin galines kaladeles po 2600km... gal kazkas slapta uz stabdzio laiko man vaziuojant? ;D
storms
Pranešimai: 220
Standartinė storms » 2016-06-22 08:21
Nuimk kanopą nuo stabdžio, nes pavažiavus dar ir siskas iki raudonumo įkaista
Standartinė rusnietis » 2016-06-22 09:07
storms rašė:Žinutės nuoroda Nuimk kanopą nuo stabdžio, nes pavažiavus dar ir siskas iki raudonumo įkaista
O as ir galvojau kas ten sviecia vakarais vaziuojant.. ;D Jei rimtai tai tik islindus i kelia kaladeliu devejimasis sustoja, o va po paskutiniu molynu/smelynu buvo isciulpti paskutiniai milimetrai ir OEM Nissinai vakar buvo pakeisti i EBC, ziuresim kaip su anais reiklai eisis ;)
storms
Pranešimai: 220
Standartinė storms » 2016-06-22 09:13
Panašu, kad pas tave dar ir suportas neplaukioja - viena kalade mirus (net kampu), kita gyva
Standartinė rusnietis » 2016-06-22 09:20
Supportas plaukioja puikiai, ir cilindriukas vaiksto lengvai. Darau prielaida, kad gal vienoj disko pusej labiau abrazyviniai shudai kaupiasi?
storms
Pranešimai: 220
Standartinė storms » 2016-06-22 09:47
Gal įvorės kreivos ar sudilusios, nes kaladė tai kreivai nudilus. Taip būt neturi
Standartinė rusnietis » 2016-06-22 09:50
Nu reiks paziuret vakare, gal kazkokiu budu susikreivino. Sudilusios tikrai neturetu buti, motociklo total rida 2600km per gera pusmeti :) Reklamacija Gondai?
storms
Pranešimai: 220
Standartinė storms » 2016-06-22 09:55
Hondos nelaiko. Faktas
Pranešimai: 2741
Stabdžių tvarkymas
Standartinė draginoid » 2017-05-25 16:38
Gal kas turi (gali) paskolinti tipo tokio daikto Vilniuje?:
Paveikslėlis[/quote]
Stabdžių tvarkymas
Standartinė mykolaila » 2017-05-25 16:39
draginoid rašė:Žinutės nuoroda Gal kas turi (gali) paskolinti tipo tokio daikto Vilniuje?:
Turiu, galiu. Vakare įsimesiu į mašiną iš garažo. Parašyk ar paskambink kada/kur patogu pasiimt.
Stabdžių tvarkymas
Standartinė Tinkladraskis » 2017-05-25 23:36
Prireikė mano Kawasaki KL 650 B Tengai galinių stabdžių armuotos žarnos.
Kur patartumėte ieškoti pirkti Lietuvoje (Vilniuje)?
Žinoma pasiteirausiu OEM detalių tiekėjų, bet reikia žinoti alteratyvas.
Sklaidantis po užsienio parduotuves matau, kad žarnelė kainuoja apie 43 Eur + siuntimas.
Nepigus malonumas :)
Stabdžių tvarkymas
Standartinė Decoy » 2017-05-25 23:44
Britų gamintojas HEL labai neblogas, pastebėjau kad pas mane irgi pakeistos stovi :D
Labai tikėtina, kad tiesiai iš gamintojo galima užsakyti.
storms
Pranešimai: 220
Stabdžių tvarkymas
Standartinė storms » 2017-05-25 23:48
Būtų nesamonė imt OEM, kai gali įdėt armuotą
Pranešimai: 2741
Stabdžių tvarkymas
Standartinė draginoid » 2017-05-26 09:17
Esu sau pirkes is eBay armuotas is DE.
Sertifikuotos ir kokybiskos.
Stabdžių tvarkymas
Standartinė Plasnart » 2017-06-27 08:20
Buvau kalnuose "užvirines" stabdzius iki neveikimo. Ataušus veikia lyg kaip įptastai. Ar gali pasikeisti stabdžių skysčio savybės ir ar būtina pasikeisti stabdžių skystį ?
