Suzuki Bandit 1250S ABS 2016
Pranešimai: 2741
Standartinė draginoid » 2015-11-16 13:51
Pradžiugino Suzuki.
Jau galvojau nebus Banditai gaminami po 2011. Ir, štai Banditas vėl pardavime 650 ir 1250 versijos.
1250 versijos aprašymas:
Engine Inline, transverse mount 4-cylinder, 4-stroke, DOHC, 1255 cm3
Bore Stroke 79.0 mm (3.110 in) x 64.0 mm (2.520 in)
Cooling medium Liquid cooled main radiator, water-cooled oil cooler
Starter Electric
Compression Ratio 10.5 : 1
Fuel System Fuel injection
Ignition Electronic ignition (Transistorized)
Lubrication Wet sump
Chassis
Brakes Front 310 mm floating dual discs
Brakes Rear 240mm single disc
Color Candy Daring Red, Glass Sparkle Black
Curb Weight 254 kg (560 lbs)
Final Drive RK GB50GSVZ3, 118 links
Fuel Tank Capacity 19 L (5.0 US gal) includes reserve
Ground Clearance 135 mm ( 5.3 in)
Overall Length 2130 mm (83.9in)
Overall Width 790 mm (31.1 in)
Seat Height 805mm (31.7 in. ) LOW setting, 825 mm (32.5 in.) HIGH setting
Suspension Front Telescopic, coil spring, oil damped (SHOWA)
Suspension Rear Single shock, coil over oil damper, link-style (SHOWA)
Tires Front 120/70ZR17M/C (58W), tubeless
Tires Rear 180/55ZR17M/C (73W), tubeless
Transmission 6-speed Close ratio, constant mesh, return shift type
Wheelbase 1485 mm (58.5 in)
Daugiau info is http://www.suzukicycles.com/Product%20Lines/Cycles/Products/Bandit%201250S/2016/GSF1250SA.aspx#Features ir http://www.revzilla.com/common-tread/preview-the-2016-suzuki-bandit-1250s
mune23
Pranešimai: 26
Užsiregistravo: 2015-11-15 10:48
Re: Suzuki Bandit 1250S ABS 2016
Standartinė mune23 » 2015-11-17 21:26
Taigi visalaik buvo gaminami ir 12 ir kitais metais. O sitas tas pats senasis banditas ejes nuo 07 mrtu, tik su truputi kitokia priekio apdaila. Net lempa ta pati liko.
Pranešimai: 2741
Standartinė draginoid » 2015-11-17 21:48
Visad matau šį modelį kaip gaminta 2007-2012, o 2014 pristatytas Kolne naujas modelis
Sent from my C5503 using Tapatalk
mune23
Pranešimai: 26
Standartinė mune23 » 2015-11-18 09:04
Kur tu matei kad 650 ir 1250 banditai nuo 12 Iki15 nebuvo gaminti?
level
Užsiregistravo: 2017-08-31 10:48
Standartinė level » 2017-09-07 20:17
Klausimas.. Ar imanoma ant 2007 650SA bandito suukininkauti universalu begiu indikatoriu?
Pranešimai: 2741
Standartinė draginoid » 2017-09-08 00:17
