Bioetanolis E85 - kas tai yra?
Visi žino kad, kuro markiracija yra susieta su oktaninis skaičiumi.
Ir, teoretiškai,Bioetanolis E85 turi prastesnius, tačiau atsižvelgiant į tai, kad jo pagrindas yra etanolis.
Tokio oktaninis skaičius siekia net 107.
Taigi, klausimai - kodėl vieni sako "jį tik į traktorius pilti" o kiti sako "wow!, tai yra auksas".
Paaiškinkite man durnam, ar "E85" gali būti skirtingų rūšių?
Citata iš straipsnio:
https://en.wikipedia.org/wiki/E85
Octane rating
As more effort is put into maximizing an engine to take advantage of E85's higher "octane", engines achieve greater power advantages. One car that has higher power on ethanol is the Koenigsegg CCXR, which on ethanol is the third-most powerful production car, with 20% more hp on E85 than on gasoline. According to the manufacturer, this is due to the cooling properties of ethanol. E85 has an octane rating higher than that of regular gasoline's typical rating of 87, or premium gasoline's 91-93. This allows it to be used in higher-compression engines, which tend to produce more power per unit of displacement than their gasoline counterparts. The Renewable Fuels Foundation states in its Changes in Gasoline IV manual, "There is no requirement to post octane on an E85 dispenser. If a retailer chooses to post octane, they should be aware that the often cited 105 octane is incorrect. This number was derived by using ethanol’s blending octane value in gasoline. This is not the proper way to calculate the octane of E85. Ethanol’s true octane value should be used to calculate E85’s octane value. This results in an octane range of 94-96 (R+M)/2. These calculations have been confirmed by actual-octane engine tests."
Lietuviai taip aprašo:
http://www.e85.lt/index.php?option=com_ ... =2&lang=lt
Vilniuje yra krūva degalinių su tokio pasiūla.
Video kuris sukėlė daug klausimų:
Gal kas bandė?
Octane rating
Gal kas bandė?
Re: E85 - kas tai yra?
Parašysiu iš buitinės pusės.
Turiu Chrysler Town&Country, kuris oficialiai gali važiuoti tiek benzinu tiek bioetanoliu.
Kuro suvartojimas mieste:
Benzas 13 - 14 litrų/100 km
E85 15-17 litrų/100 km
Pagrindinis jo naudojimo argumentas yra pinigų taupymas, bet aš 100km sutaupau tik apie 1 Eur važiuodamas su E85. Juo važinėti man apsimoka tik kai kainų skirtumas būna bent 0,2 Eur/litras.
Bioetanolis nėra toks kaloringas, todėl jo turi būti supilama į mišinį cilindre daugiau nei benzo.
Automobilyje yra gamyklinis mygtukas, kurį nuspaudus kompiuteris keičia kuro mišinio santykį.
Vilniuje yra likusios tik dvi degalinės, kurios pila E85.
Kuro padavimo sistema turi būti pritaikyta E85 nausojimui. Antraip E85 esantis spiritas gali pažeisti kai kurias tarpines, kurioa neatsparios spirito poveikiui.
Aš klausiau pas Subaru dilerio darbuotoją, ar galiu pilti į savo. Atsakymas buvo neigiamas, nes procentinė dalis per didelė. Iki kažkokio lygio skiestą gamintojas leidžia, bet- šito jau nebe.
Re: Bioetanolis E85 - kas tai yra?
Jame yra 85% etanolio ir 15% benzino.
Tinkladraskis rašė:Žinutės nuoroda Jame yra 85% etanolio ir 15% benzino.
Kartai ne atvirkščiai?
monte rašė:Žinutės nuorodaTinkladraskis rašė:Žinutės nuoroda Jame yra 85% etanolio ir 15% benzino.
Viskas teisingai
Dar egzistuoja E5, E10, E95 ir E100.
Realiai paprastiems varikliams tinka iki E30, tada kuro ekonomija gali siekti 1%
Ačiū už atsakymus, daugmaž aiškiau dabar
Dėl degalinių - tai prie pat mano namų yra viena ir tas E85 vis akis bado.
O dėl privalumų, tai pagrindinis visgi yra tame kad atnaujinamas energijos šaltinis.
Vartotojui, aišku, tai nėra labai aktualu šiai dienai, bet kažkiek moralinio malonumo prideda
Aš irgi buvau labai susidomėjęs tuo bioetanoliu, tačiau pradėjus domėtis supratau, kad tai nėra gera idėja, juolab motociklams. Kalbėjau su ralio mechanikais, nes, kaip žinia, ralyje naudoja būtent e85, tačiau jie visą motoro sistemą pritaiko būtent jam ir tuomet gali išspausti bombą iš paprasto EVO VIII motoro. BET pilant pastoviai į savo kasdieninę transporto priemonę nei ekonomijos, nei efektyvumo neišgausi, o netgi yra tikimybė traukos sumažėjimui kol galiausiai nep0radėsi pilti normalaus benzino. Tad reziume - neverta susivilioti keliais pigesniais litrais kuro vardan gražiai dirbančio variklio.
On a bike no one ever asks "are we there yet"
I savo sena masina pildavau, be jokiu pakeitimu, bet tik vasara kai silta. Bet po ivairiu eksperimentu nusprendziau, kad verta tik kai vaziuoji toli ir prisipili ir isvazineji per pora dienu, pvz nuvaziuoti is Vilniaus i Klaipeda ir atgal. Tokiu budu tikrai susitaupo. Bet mieste vazineti neverta, nes padideja sanaudos, sumazeja galia, o esant zemesnei temperaturai, pvz +12 sunkiai uzsiveda. Be to manau, kad toks naudojimas kenkia varikliui, nes jis dirba liesesniu misiniu, del ko gali labiau kaisti ismetimo voztuvai ir pan.. Dar spiritas "traukia" vandeni ir jei sistema nepritaikyta tai gali pradeti rudyti vamzdeliai ir visa kita, kas lieciasi su kuru.
Be to yra vienas E85 minusas.
Tavo garažas pradeda kvepėti, kaip senas alkoholikas.
Tinkladraskis rašė:Žinutės nuoroda Be to yra vienas E85 minusas.
Ar tai minusas? Gali visad nueiti pas savo sena drauga alkoholika
